[Bio] / MGRAST / metagenomics.cgi Repository:
Log of /MGRAST/metagenomics.cgi
Links to mgrast_dev_05262011: (view) (download) (annotate)
Tue May 3 18:16:40 2011 UTC (9 years, 1 month ago) by jared
CVS Tags: HEAD, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012
switched jquery back to 1.4.2 for feed compatibility
Thu Apr 28 22:01:49 2011 UTC (9 years, 1 month ago) by tharriso
Changes since 1.9: +1 -0 lines
added rephael to global js
Wed Apr 27 23:42:58 2011 UTC (9 years, 1 month ago) by jared
Changes since 1.8: +1 -4 lines
browse page modification
Tue Apr 19 20:50:18 2011 UTC (9 years, 1 month ago) by jared
Changes since 1.7: +2 -0 lines
added pretty forms js
Wed Apr 6 11:12:31 2011 UTC (9 years, 2 months ago) by paczian
CVS Tags: mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0_4
Changes since 1.6: +2 -0 lines
added favicon support
Wed Nov 3 12:45:46 2010 UTC (9 years, 7 months ago) by paczian
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03052011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3
set browser checking to strict
Fri Oct 23 06:02:01 2009 UTC (10 years, 7 months ago) by jared
CVS Tags: myrast_33
Changes since 1.4: +2 -1 lines
Mon Oct 12 11:41:12 2009 UTC (10 years, 7 months ago) by paczian
Changes since 1.3: +11 -16 lines
new style
Mon Feb 16 20:57:31 2009 UTC (11 years, 3 months ago) by jared
Fixed help links
Tue Nov 4 20:44:24 2008 UTC (11 years, 7 months ago) by jared
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2
updated help links
Wed Oct 22 11:04:33 2008 UTC (11 years, 7 months ago) by paczian
Branch point for: rastcode
