[Bio] / MExplorer / xduGen.cc Repository:
Log of /MExplorer/xduGen.cc
Links to V00-00-00: (view) (download) (as text) (annotate)
Mon Jan 6 23:32:23 2003 UTC (16 years, 11 months ago) by efrank
CVS Tags: V00-00-00
Changes since 1.1: +33 -10 lines
xduGen.cc:
	modify to take an arg (mandatory) that says what process node to start with when dumping
lsCatDb.pcc
	guts of lsCat.  lists the reco catalog.  separated from lsCat itself to simplify
	the makefile.
xduViz
	script to call xduGen followed by invocation of xdu.  takes xdu from ~efrank
	since it is not installed. all hardwired.  gasp.
lsCatdb.pcc
	removed in favor of lsCatDb.pcc so that filename matches function name.
Fri Dec 20 20:12:20 2002 UTC (16 years, 11 months ago) by efrank
Branch point for: local
