[Bio] / LIMS / Makefile Repository:
View of /LIMS/Makefile
Revision 1.1.1.1 - (download) (annotate) (vendor branch)
Thu Feb 28 21:16:00 2008 UTC (11 years, 9 months ago) by jared
Branch: ANL, MAIN
CVS Tags: initial-version, HEAD
lims-server
# Public License.
# seed_running_perl.fragement is the piece of perl code that
# checks to see if the seed server is up, and prints a message and returns
# if it is not.
SEED_RUNNING_PERL = seed_running_perl.fragment
PERLCGISCRIPTS := $(subst .pl,,$(wildcard *.cgi))
PERL_LIB = $(wildcard *.pm) \
	$(wildcard WebPage/*.pm) \
	$(wildcard LIMSBackend/*.pm)
WEBPAGES := $(wildcard *.tmpl) \
	$(wildcard images/*.png) \
	$(wildcard images/*.jpeg) \
	$(wildcard images/*.gif) \
	$(wildcard css/*.css) \
	$(wildcard js/*.js)
INST_PERL_LIB = $(foreach var, $(PERL_LIB), $(libdir)/$(PKGNAME)/$(var))
all: lib
show:
	@echo cgis $(foreach var, $(PERLCGISCRIPTS), $(cgidir)/$(var))
	@echo top $(TOPDIR)
	@echo pkg $(PKGNAME)
	@echo toolhdr $(TOOL_HDR)
bin:
lib:	$(foreach var, $(PERLCGISCRIPTS), $(cgidir)/$(var)) copy_htaccess $(INST_PERL_LIB) $(foreach var, $(WEBPAGES), $(cgidir)/Html/$(var)) rights
htaccess_src = $(RTROOT)/config/all.htaccess
htaccess_dst = $(cgidir)/.htaccess
copy_htaccess: force
	if test -f $(htaccess_src); then \
		 cp $(htaccess_src) $(htaccess_dst) ; \
	fi
force:
schematools:
stDeclFiles:
stGeneratedFiles:
test:
clean:
$(cgidir)/%: $(TOPDIR)/$(PKGNAME)/% $(TOOL_HDR)
	( cat $(TOOL_HDR) $< > $@; chmod +x $@ )
$(cgidir)/Html/%: $(TOPDIR)/$(PKGNAME)/%
	cp -p $< $(cgidir)/Html/.
# We have a config problem at the moment.  I do not want to depend
# upon explicit calls to other packages, as done here nor do I want
# to assume that package was built first.  For now, we live with this.
#$(TOOL_HDR):
#	cd $(workdir); $(TOPDIR)/FigCommon/configure-env $(RTARCH) $(TOPDIR)
# Since our lib files have directories, need to create the target
# directory if it doesn't yet exist.
$(libdir)/$(PKGNAME)/%.pm: $(TOPDIR)/$(PKGNAME)/%.pm
	tgt_dir=`dirname $@`;  \
	if [ ! -d $$tgt_dir ] ; then \
		mkdir $$tgt_dir; \
	fi
	cp -p  $< $@
rights:
	cd $(TOPDIR)/WebApplication/scripts; \
	perl create_application_rights_module.pl -path $(TOPDIR) -application $(PKGNAME)
