[Bio] / KahApp / __init__.py Repository:
Log of /KahApp/__init__.py
Default branch: initial
Thu Jul 8 01:41:30 2004 UTC (15 years, 5 months ago) by efrank
Branch: MAIN, initial
CVS Tags: HEAD, V00-00-00, before-dynamics-persistence, forRick-14Jul04-0, forRick-14Jul04-1, lwc, mass-spec-01, mass-spec-02, mass-spec-03, post-st-migration, post-st-migration2, preTreatmanDyn, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4, treatman-lastDay-0, v0
Initial load of package KahApp.  KahApp will hold stuff particular to the
execution framework and , at least for now, configuration of modules.
Branch point for: MAIN, initial
