[Bio] / KahApp / Makefile Repository:
Log of /KahApp/Makefile
Revision 1.3 - (view) (download) (annotate) - [selected]
Tue Jan 17 17:12:47 2006 UTC (14 years ago) by efrank
CVS Tags: HEAD, lwc
persistence for dynamics stuff
bunch of flux modelinig stuff including flux model building in modeleditor
Fri Mar 11 21:33:13 2005 UTC (14 years, 10 months ago) by efrank
CVS Tags: before-dynamics-persistence, preTreatmanDyn, treatman-lastDay-0
1. introduce Model as king of the hill rather than RecoElem.
2. migrations to follow
3. new modules for by-peg filtering
4. first stab at externalized app fwk
5. moved seed data factory
bunch of timing code still in this ...need to take out
Fri Sep 10 13:30:18 2004 UTC (15 years, 4 months ago) by efrank
CVS Tags: post-st-migration, post-st-migration2, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
Diff to selected 1.3
addeda makefile
