[Bio] / KahApp / KahFwk.py Repository:
Log of /KahApp/KahFwk.py
Tue Jan 17 17:12:47 2006 UTC (13 years, 9 months ago) by efrank
CVS Tags: HEAD, lwc
Changes since 1.1: +49 -25 lines
persistence for dynamics stuff
bunch of flux modelinig stuff including flux model building in modeleditor
Fri Mar 11 21:33:13 2005 UTC (14 years, 8 months ago) by efrank
CVS Tags: before-dynamics-persistence, preTreatmanDyn, treatman-lastDay-0
Diff to selected 1.2
1. introduce Model as king of the hill rather than RecoElem.
2. migrations to follow
3. new modules for by-peg filtering
4. first stab at externalized app fwk
5. moved seed data factory
bunch of timing code still in this ...need to take out
