[Bio] / KahApp / KahConfigMgr.py Repository:
Log of /KahApp/KahConfigMgr.py
Fri Mar 11 21:33:13 2005 UTC (14 years, 9 months ago) by efrank
CVS Tags: HEAD, before-dynamics-persistence, lwc, preTreatmanDyn, treatman-lastDay-0
1. introduce Model as king of the hill rather than RecoElem.
2. migrations to follow
3. new modules for by-peg filtering
4. first stab at externalized app fwk
5. moved seed data factory
bunch of timing code still in this ...need to take out
Fri Jan 7 14:40:32 2005 UTC (14 years, 11 months ago) by efrank
CVS Tags: post-st-migration, post-st-migration2
Changes since 1.2: +30 -12 lines
migration to new schematools generated classes.
new chemdb.
factor chem out of seed data factory
imporved configuration of modeleditor
Thu Jul 8 17:39:18 2004 UTC (15 years, 5 months ago) by efrank
CVS Tags: V00-00-00, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
Changes since 1.1: +5 -0 lines
Set xform in ConfigParser to str() so that case sensitivity is preserved
in option names.
Thu Jul 8 01:41:30 2004 UTC (15 years, 5 months ago) by efrank
Branch point for: initial
