[Bio] / KBaseTutorials / tutorial-dir-map Repository:
View of /KBaseTutorials/tutorial-dir-map
Revision 1.2 - (download) (annotate)
Fri Sep 7 20:36:02 2012 UTC (7 years, 3 months ago) by nconrad
CVS Tags: HEAD
updating directory mapping
getting-started	getting_started.html
getting-started	basic_exercises.html
getting-started	command_line_pipes.html
getting-started	KBase_dev_in_seed.html
command-line-scripts/accessing-central-store-data	command_line_pipes.html
command-line-scripts/accessing-central-store-data	The_Corresponds_and_Close_Genomes_Commands.html
apis/getting-started-with-kbase-apis	CS-API_UI.html
command-line-scripts/command-line-applications	processing_identical_genomes.html
apis/example-tasks	features_with_identical_sequence.html
apis/example-tasks	comparing_functional_roles.html
apis/example-tasks	retrieving_functional_coupling_data.html
command-line-scripts/command-line-applications	towards_a_controlled_vocabulary.html
command-line-scripts/command-line-applications	exemplars.html
command-line-scripts/command-line-applications	mapping_to_exemplars.html
command-line-scripts/command-line-applications	making_the_MOL_translation.html
command-line-scripts/command-line-applications	mapping_functions_take2.html
iris IRIS.html
