[Bio] / FortyEightMeta / recover_broken_job.pl Repository:
Log of /FortyEightMeta/recover_broken_job.pl
Mon Sep 1 19:51:41 2008 UTC (11 years, 5 months ago) by redwards
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2
Changes since 1.4: +8 -0 lines
adding a tag to meta xml and allowing the dot directory
Tue Aug 19 20:56:57 2008 UTC (11 years, 6 months ago) by dsouza
Changes since 1.3: +20 -11 lines
Modified so absence of an error file (from a BLAST run) indicates the BLAST
run failed. This is not strictly true if the BLAST run has not yet
completed.
Fri Mar 28 20:18:38 2008 UTC (11 years, 11 months ago) by olson
CVS Tags: mgrast_rel_2008_0806
Changes since 1.2: +6 -1 lines
fixes to job fixer
Sun Mar 16 03:22:22 2008 UTC (11 years, 11 months ago) by redwards
need to repair one jobs too!
Mon Mar 10 16:30:26 2008 UTC (11 years, 11 months ago) by olson
Code for resubmitting sims for a broken job.
