[Bio] / FortyEightMeta / mg_sims_done.pl Repository:
View of /FortyEightMeta/mg_sims_done.pl
Fri Mar 23 20:41:31 2007 UTC (12 years, 10 months ago) by olson
CVS Tags: mgrast_dev_08112011, mgrast_dev_08022011, mgrast_dev_05262011, mgrast_dev_04082011, mgrast_version_3_2, mgrast_dev_12152011, mgrast_dev_06072011, mgrast_rel_2008_0806, mgrast_dev_10262011, mgrast_dev_02212011, mgrast_rel_2008_0923, mgrast_release_3_0, mgrast_dev_03252011, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, mgrast_dev_04012011, mgrast_rel_2008_0919, mgrast_rel_2008_1110, myrast_33, mgrast_rel_2008_0917, mgrast_dev_04052011, mgrast_dev_02222011, HEAD
initial checking of metagenome 48 stuff
# Trivial script that is submitted as a postprocessor to the sims runs that marks
# the sims stage as complete.
use strict;
use FIG;
use FIG_Config;
use File::Basename;
use GenomeMeta;
use Job48;
use SGE;
my $STAGE = "sims";
@ARGV == 1 or die "Usage: $0 job-dir\n";
my $jobdir = shift;
-d $jobdir or die "$0: job dir $jobdir does not exist\n";
my $job_id = basename($jobdir);
my $job = new Job48($job_id);
my $meta = $job->meta;
print "Running job! $jobdir\n";
$job->meta->set_metadata("status.$STAGE", "complete");
$job->meta->set_metadata("$STAGE.running", "no");
sub run
    my(@cmd) = @_;
    print "Run @cmd\n";
    my $rc = system(@cmd);
    if ($rc != 0)
	&fatal("Failed with rc=$rc: @cmd");
sub fatal
    my($msg) = @_;
    $meta->add_log_entry($0, ['fatal error', $msg]);
    $meta->set_metadata("status.$STAGE", "error");
    croak "$0: $msg";
