[Bio] / FortyEightMeta / mg_load_done.pl Repository:
Log of /FortyEightMeta/mg_load_done.pl
Links to mgrast_rel_2008_0806: (view) (download) (as text) (annotate)
Thu Jun 12 21:35:53 2008 UTC (11 years, 11 months ago) by olson
Changes since 1.2: +15 -0 lines
Replace the MLDBM/DB_File sim status database with a postgres version.
Wed Jun 11 21:16:42 2008 UTC (11 years, 11 months ago) by olson
Commit of initial MGRAST2 code.
Fri May 30 23:23:51 2008 UTC (12 years ago) by olson
Development checkin of new metagenomics RAST pipeline.
