[Bio] / FortyEightMeta / mg_compute_sims_on_timelogic.pl Repository:
Log of /FortyEightMeta/mg_compute_sims_on_timelogic.pl
Revision 1.9 - (view) (download) (as text) (annotate) - [selected]
Thu Oct 11 16:37:35 2007 UTC (12 years, 9 months ago) by mkubal
Changes since 1.8: +11 -6 lines
-priority 5, records SOC job to meta.xml
Thu Oct 11 14:38:33 2007 UTC (12 years, 9 months ago) by mkubal
Changes since 1.7: +3 -3 lines
Diff to previous 1.7 , to selected 1.9
-priority 9
Mon Oct 8 16:36:33 2007 UTC (12 years, 9 months ago) by mkubal
Diff to previous 1.6 , to selected 1.9
fixed premature setting of sims stage as complete
Wed Oct 3 18:02:57 2007 UTC (12 years, 9 months ago) by mkubal
Diff to previous 1.5 , to selected 1.9
added ssu to database list
Wed Oct 3 15:42:05 2007 UTC (12 years, 9 months ago) by mkubal
Diff to previous 1.4 , to selected 1.9
uses different template for each db
Mon Oct 1 20:42:51 2007 UTC (12 years, 9 months ago) by mkubal
Diff to previous 1.3 , to selected 1.9
set stage to done when finished
Thu Sep 27 19:48:15 2007 UTC (12 years, 9 months ago) by mkubal
Diff to previous 1.2 , to selected 1.9
sleep for 1 min between status checks
Wed Sep 26 15:55:38 2007 UTC (12 years, 9 months ago) by mkubal
Diff to previous 1.1 , to selected 1.9
gets correct fa file
Mon Sep 24 18:02:35 2007 UTC (12 years, 9 months ago) by mkubal
Diff to selected 1.9
running sims on timelogic
