[Bio] / FortyEightMeta / mg_compute_sims.pl Repository:
Log of /FortyEightMeta/mg_compute_sims.pl
Fri Jun 13 01:58:12 2008 UTC (11 years, 8 months ago) by olson
Changes since 1.4: +4 -0 lines
Add connect/disconnect to SimStatusDB. Disconnect while sims run.
Thu Jun 12 21:35:53 2008 UTC (11 years, 8 months ago) by olson
Changes since 1.3: +19 -31 lines
Replace the MLDBM/DB_File sim status database with a postgres version.
Wed Jun 11 21:16:42 2008 UTC (11 years, 8 months ago) by olson
Changes since 1.2: +99 -9 lines
Commit of initial MGRAST2 code.
Fri May 30 23:23:51 2008 UTC (11 years, 8 months ago) by olson
Changes since 1.1: +41 -5 lines
Development checkin of new metagenomics RAST pipeline.
Fri Mar 23 20:49:08 2007 UTC (12 years, 11 months ago) by olson
fixes
