[Bio] / FortyEightMeta / mg_check_sims.pl Repository:
Log of /FortyEightMeta/mg_check_sims.pl
Thu Jun 12 21:35:53 2008 UTC (11 years, 8 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2
Changes since 1.1: +3 -6 lines
Replace the MLDBM/DB_File sim status database with a postgres version.
Fri May 30 23:23:51 2008 UTC (11 years, 8 months ago) by olson
Development checkin of new metagenomics RAST pipeline.
