[Bio] / FortyEightMeta / load_tax.pl Repository:
Log of /FortyEightMeta/load_tax.pl
Fri Mar 28 20:18:49 2008 UTC (11 years, 10 months ago) by olson
Changes since 1.2: +65 -65 lines
Updates to mgrast sim loader.
Thu Mar 27 17:13:13 2008 UTC (11 years, 10 months ago) by olson
Changes since 1.1: +51 -3 lines
Makefile tweak (missing the teragrid sims script); updates to the sims loader code for integration with new server.
Thu Mar 13 21:32:00 2008 UTC (11 years, 11 months ago) by olson
Sim loading code.
