[Bio] / FortyEightMeta / finish_job.pl Repository:
Log of /FortyEightMeta/finish_job.pl
Links to mgrast_dev_02212011: (view) (download) (as text) (annotate)
Fri Apr 3 05:38:24 2009 UTC (11 years, 2 months ago) by redwards
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33
Changes since 1.1: +5 -3 lines
changing the user object accessors
Sun Dec 21 19:07:56 2008 UTC (11 years, 5 months ago) by redwards
adding finish_job to mg-rast. This just finishes incomplete jobs using code stolen from other places. Why are they breaking?
