[Bio] / FortyEightMeta / check_jobs_mg.pl Repository:
Log of /FortyEightMeta/check_jobs_mg.pl
Wed Aug 27 17:57:06 2008 UTC (11 years, 5 months ago) by olson
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33
Changes since 1.17: +6 -0 lines
Diff to previous 1.17
add mgrast2 check
Fri Jun 20 20:09:05 2008 UTC (11 years, 8 months ago) by olson
CVS Tags: mgrast_rel_2008_0806
Changes since 1.16: +4 -4 lines
Diff to previous 1.16
Rollup of MGRAST changes.
Fri May 30 23:23:51 2008 UTC (11 years, 8 months ago) by olson
Changes since 1.15: +6 -3 lines
Development checkin of new metagenomics RAST pipeline.
Fri May 16 22:18:09 2008 UTC (11 years, 9 months ago) by olson
Changes since 1.14: +9 -7 lines
snapshot of mgrast work
Tue Apr 1 18:35:11 2008 UTC (11 years, 10 months ago) by dsouza
Changed URL in email sent to user on job completion.
Wed Oct 31 17:14:07 2007 UTC (12 years, 3 months ago) by olson
Changes since 1.12: +15 -0 lines
Add disk freespace check.
Wed Sep 26 17:56:28 2007 UTC (12 years, 4 months ago) by mkubal
no_localdb
Wed Sep 26 15:54:41 2007 UTC (12 years, 4 months ago) by mkubal
Changes since 1.10: +2 -1 lines
added no_local_db arg
Tue Sep 25 19:47:14 2007 UTC (12 years, 4 months ago) by mkubal
using bioblasta for sims
Mon Sep 24 18:01:40 2007 UTC (12 years, 4 months ago) by mkubal
Changes since 1.8: +3 -2 lines
added mg_compute_sims_on_timelogic
Thu Sep 13 21:17:26 2007 UTC (12 years, 5 months ago) by olson
Changes since 1.7: +1 -0 lines
Rollup of changes made on dev system.
Fri Jul 6 21:21:51 2007 UTC (12 years, 7 months ago) by olson
MG server updates
Sat Apr 14 22:16:10 2007 UTC (12 years, 10 months ago) by olson
foo
Sat Apr 14 01:11:05 2007 UTC (12 years, 10 months ago) by olson
set status.complete
Fri Apr 13 20:54:17 2007 UTC (12 years, 10 months ago) by olson
minor fixes
Fri Apr 13 17:46:18 2007 UTC (12 years, 10 months ago) by olson
chage running back to in_progress
Fri Mar 23 20:48:35 2007 UTC (12 years, 10 months ago) by olson
fixes
Fri Mar 23 20:41:31 2007 UTC (12 years, 10 months ago) by olson
initial checking of metagenome 48 stuff
