[Bio] / FortyEight / send_job_completion_email.pl Repository:
Log of /FortyEight/send_job_completion_email.pl
Links to mgrast_dev_04052011: (view) (download) (as text) (annotate)
Tue Jan 19 00:09:14 2010 UTC (10 years ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.1: +1 -2 lines
remove debug
Fri Jan 15 20:35:59 2010 UTC (10 years ago) by olson
Add job-completion email script (since we send from both the main pipeline
and from the replicate_job script)
