[Bio] / FortyEight / rp_write_spreadsheets.pl Repository:
View of /FortyEight/rp_write_spreadsheets.pl
Wed Jun 8 20:58:35 2011 UTC (8 years, 7 months ago) by olson
CVS Tags: mgrast_dev_08112011, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2014_0729, mgrast_release_3_1_2, mgrast_release_3_1_1, rast_rel_2011_0928, mgrast_version_3_2, mgrast_dev_12152011, mgrast_dev_10262011, HEAD
Spreadsheet export, new script for dumping queue data.
# Write the export files for this completed job.
use Data::Dumper;
use Carp;
use strict;
use FIG;
use FIG_Config;
use FileHandle;
use File::Basename;
use GenomeMeta;
use SeedExport;
use Job48;
@ARGV == 1 or die "Usage: $0 job-dir\n";
my $jobdir = shift;
-d $jobdir or die "$0: job dir $jobdir does not exist\n";
my $job = new Job48($jobdir);
$job or die "cannot create job for $jobdir";
my $hostname = `hostname`;
chomp $hostname;
my $genome = &FIG::file_head("$jobdir/GENOME_ID");
chomp $genome;
$genome =~ /^\d+\.\d+/ or die "$0: Cannnot find genome ID for jobdir $jobdir\n";
my $meta = new GenomeMeta($genome, "$jobdir/meta.xml");
my $genome_dir = "$jobdir/rp/$genome";
my $export_dir = "$jobdir/download";
&FIG::verify_dir($export_dir);
my @idx;
open(I, "<", "$export_dir/index");
while (<I>)
    chomp;
    if (!/spreadsheet/i)
	push(@idx, $_);
close(I);
my $ss_txt = "$export_dir/$genome.txt";
my $ss_xls = "$export_dir/$genome.xls";
my $rc = system("$FIG_Config::bin/seed2txt", "--out", $ss_txt, "--orgdir", $genome_dir, $genome);
if ($rc == 0)
    push(@idx, "$genome.txt\tSpreadsheet (tab-separated text format)");
    my $url = "$FIG_Config::cgi_url/seedviewer.cgi?page=Annotation&feature=PEG";
    $rc = system("$FIG_Config::bin/svr_file_to_spreadsheet -u '$url' -f $ss_xls < $ss_txt");
    if ($rc == 0)
	push(@idx, "$genome.xls\tSpreadsheet (Excel XLS format)");
    else
	warn "error $rc writing XLS\n";
else
    warn "error $rc writing txt spreadsheet\n";
if (open(I, ">", "$export_dir/index"))
    print I "$_\n" foreach @idx;
    close(I);
exit(0);
sub fatal
    my($msg) = @_;
    if ($meta)
	$meta->add_log_entry($0, ['fatal error', $msg]);
	$meta->set_metadata("export.running", "no");
	$meta->set_metadata("status.export", "error");
    croak "$0: $msg";
