[Bio] / FortyEight / rp_write_exports.pl Repository:
Log of /FortyEight/rp_write_exports.pl
Tue Aug 12 20:14:21 2008 UTC (11 years, 7 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_release_2008_09_29
Changes since 1.3: +34 -0 lines
Rollup of RAST release changes.
Wed Feb 13 19:06:48 2008 UTC (12 years, 1 month ago) by olson
CVS Tags: rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21
Create contig btrees if not already there; this HUGEly accelerates download creation on large genomes.
Wed Feb 13 18:02:11 2008 UTC (12 years, 1 month ago) by olson
Changes since 1.1: +42 -16 lines
Fix exports.
Mon Feb 11 21:45:26 2008 UTC (12 years, 1 month ago) by olson
Add support for deadline scheduling & job export.
