Log of /FortyEight/rp_rapid_propagation.pl
Parent Directory
Revision
1.20 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Sep 29 16:21:39 2010 UTC (9 years, 2 months ago) by
olson
Branch:
MAIN
CVS Tags:
mgrast_dev_02212011,
mgrast_dev_02222011,
mgrast_dev_03252011,
mgrast_dev_03312011,
mgrast_dev_04012011,
mgrast_dev_04052011,
mgrast_dev_04082011,
mgrast_dev_04132011,
mgrast_dev_05262011,
mgrast_dev_06072011,
mgrast_dev_08022011,
mgrast_dev_08112011,
mgrast_release_3_0,
mgrast_release_3_0_1,
mgrast_release_3_0_2,
mgrast_release_3_0_3,
mgrast_release_3_0_4,
mgrast_release_3_1_0,
mgrast_release_3_1_1,
myrast_33,
rast_rel_2010_1206,
rast_rel_2011_0119
Changes since
1.19: +1 -1 lines
Diff to
previous 1.19
make invalid rp a fatal error
Revision
1.9 -
view)
download)
as text)
annotate)
[select for diffs]
Tue Jun 17 16:44:21 2008 UTC (11 years, 5 months ago) by
olson
Branch:
MAIN
CVS Tags:
mgrast_rel_2008_0625,
mgrast_rel_2008_0806,
mgrast_rel_2008_0917,
mgrast_rel_2008_0919,
mgrast_rel_2008_0923,
mgrast_rel_2008_0924,
rast_2008_0924,
rast_rel_2008_06_18,
rast_rel_2008_07_21,
rast_rel_2008_08_07,
rast_rel_2008_09_29,
rast_rel_2008_09_30,
rast_rel_2008_10_09,
rast_rel_2008_10_29,
rast_release_2008_09_29
Changes since
1.8: +1 -1 lines
Diff to
previous 1.8
fix typo
Revision
1.3 -
view)
download)
as text)
annotate)
[select for diffs]
Wed May 9 20:57:37 2007 UTC (12 years, 7 months ago) by
olson
Branch:
MAIN
Changes since
1.2: +17 -1 lines
Diff to
previous 1.2
Add support for keeping gene calls (add --keep to rapid_propagation invocation when
metadata keep_genecalls is set).
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
