[Bio] / FortyEight / rp_rapid_propagation.pl Repository:
Log of /FortyEight/rp_rapid_propagation.pl
Wed Nov 5 22:39:29 2008 UTC (11 years, 2 months ago) by olson
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26
Changes since 1.9: +7 -1 lines
When splitting, obey $FIG_Config::rast_contig_ambig_split_size
Tue Jun 17 16:44:21 2008 UTC (11 years, 7 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
fix typo
Tue Jun 17 16:12:32 2008 UTC (11 years, 7 months ago) by olson
Changes since 1.7: +12 -0 lines
Add --code argument to rapid_propagation.
Wed Oct 10 20:50:55 2007 UTC (12 years, 3 months ago) by olson
CVS Tags: rast_rel_2008_04_23, rast_rel_2008_06_16
Changes since 1.6: +19 -3 lines
Wed Sep 5 21:43:18 2007 UTC (12 years, 4 months ago) by olson
fix compile errors
Fri Jun 8 19:20:20 2007 UTC (12 years, 7 months ago) by olson
add error reason to metadata
use expanded sims instead of unexpanded sims in autoassign
Fri Jun 1 16:26:26 2007 UTC (12 years, 7 months ago) by olson
Add scenario computation.
Wed May 9 20:57:37 2007 UTC (12 years, 8 months ago) by olson
Changes since 1.2: +17 -1 lines
Add support for keeping gene calls (add --keep to rapid_propagation invocation when
metadata keep_genecalls is set).
Wed Feb 14 14:02:06 2007 UTC (12 years, 11 months ago) by olson
fix bug in fatal()
Thu Feb 1 20:03:54 2007 UTC (12 years, 11 months ago) by olson
rollup of 48hr fixes
