[Bio] / FortyEight / rp_rapid_propagation.pl Repository:
Log of /FortyEight/rp_rapid_propagation.pl
Wed Sep 29 16:21:39 2010 UTC (9 years, 3 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, rast_rel_2010_1206, rast_rel_2011_0119
Diff to previous 1.19
make invalid rp a fatal error
Wed Sep 29 16:21:04 2010 UTC (9 years, 3 months ago) by olson
Changes since 1.18: +3 -1 lines
Diff to previous 1.18
add rp4 to allowed-scripts list
Thu Jul 29 20:06:51 2010 UTC (9 years, 5 months ago) by olson
Changes since 1.17: +2 -1 lines
Diff to previous 1.17
Add rapid_propagation3 as a valid rp script.
Thu Jun 17 21:33:40 2010 UTC (9 years, 7 months ago) by olson
Changes since 1.16: +5 -1 lines
Diff to previous 1.16
Allow some users to be configured to use the old rapid propagation code.
Wed Apr 14 16:43:51 2010 UTC (9 years, 9 months ago) by olson
CVS Tags: rast_rel_2010_0526
fix logging error
Wed Apr 14 16:16:29 2010 UTC (9 years, 9 months ago) by olson
Changes since 1.14: +11 -1 lines
Add support for choosing rapid propagation script via the config file.
Mon Jan 4 20:30:23 2010 UTC (10 years ago) by olson
CVS Tags: rast_rel_2010_0118
mods from batch rasting
Tue Jun 23 21:31:50 2009 UTC (10 years, 7 months ago) by olson
typo fixes
Tue Jun 23 21:18:48 2009 UTC (10 years, 7 months ago) by olson
Changes since 1.11: +26 -0 lines
add call_using_glimmer
Mon May 18 16:54:56 2009 UTC (10 years, 8 months ago) by olson
CVS Tags: rast_rel_2009_05_18
Changes since 1.10: +27 -0 lines
rollup of production fixes
Wed Nov 5 22:39:29 2008 UTC (11 years, 2 months ago) by olson
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26
Changes since 1.9: +7 -1 lines
When splitting, obey $FIG_Config::rast_contig_ambig_split_size
Tue Jun 17 16:44:21 2008 UTC (11 years, 7 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
fix typo
Tue Jun 17 16:12:32 2008 UTC (11 years, 7 months ago) by olson
Changes since 1.7: +12 -0 lines
Add --code argument to rapid_propagation.
Wed Oct 10 20:50:55 2007 UTC (12 years, 3 months ago) by olson
CVS Tags: rast_rel_2008_04_23, rast_rel_2008_06_16
Changes since 1.6: +19 -3 lines
Wed Sep 5 21:43:18 2007 UTC (12 years, 4 months ago) by olson
fix compile errors
Fri Jun 8 19:20:20 2007 UTC (12 years, 7 months ago) by olson
add error reason to metadata
use expanded sims instead of unexpanded sims in autoassign
Fri Jun 1 16:26:26 2007 UTC (12 years, 7 months ago) by olson
Add scenario computation.
Wed May 9 20:57:37 2007 UTC (12 years, 8 months ago) by olson
Changes since 1.2: +17 -1 lines
Add support for keeping gene calls (add --keep to rapid_propagation invocation when
metadata keep_genecalls is set).
Wed Feb 14 14:02:06 2007 UTC (12 years, 11 months ago) by olson
fix bug in fatal()
Thu Feb 1 20:03:54 2007 UTC (12 years, 11 months ago) by olson
rollup of 48hr fixes
