[Bio] / FortyEight / rp_quality_check.pl Repository:
Log of /FortyEight/rp_quality_check.pl
Wed Oct 10 20:50:55 2007 UTC (12 years, 3 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_release_2008_09_29
Wed Sep 5 21:43:18 2007 UTC (12 years, 4 months ago) by olson
Changes since 1.10: +1 -0 lines
fix compile errors
Fri May 11 21:57:55 2007 UTC (12 years, 8 months ago) by olson
change email references from 48-hour to RAST
Fri May 11 17:43:26 2007 UTC (12 years, 8 months ago) by olson
minor bugfix
Wed May 9 21:35:09 2007 UTC (12 years, 8 months ago) by olson
Changes since 1.7: +28 -10 lines
fix automated correction support
Tue Mar 6 16:36:40 2007 UTC (12 years, 10 months ago) by olson
bug
Thu Mar 1 19:01:13 2007 UTC (12 years, 10 months ago) by olson
bugfix
Tue Feb 27 21:00:27 2007 UTC (12 years, 10 months ago) by olson
Changes since 1.4: +52 -0 lines
move email support to Job48
remove stopligth status
make quality_check set up correction.status and correction.request if corrections needed
Thu Nov 30 04:59:59 2006 UTC (13 years, 1 month ago) by olson
doh, fix copy/paste error in &fatal
Tue Nov 28 17:49:08 2006 UTC (13 years, 1 month ago) by olson
48-hr quality fixes
Fri Nov 24 20:44:08 2006 UTC (13 years, 1 month ago) by olson
Changes since 1.1: +4 -1 lines
updates to 48 code
Wed Nov 22 21:01:42 2006 UTC (13 years, 2 months ago) by olson
48hr mods
