[Bio] / FortyEight / rp_quality_check.pl Repository:
View of /FortyEight/rp_quality_check.pl
Revision 1.8 - (download) (as text) (annotate)
Wed May 9 21:35:09 2007 UTC (12 years, 8 months ago) by olson
Changes since 1.7: +28 -10 lines
fix automated correction support
# -*- perl -*-
# Public License.
use strict;
use GenomeMeta;
use FIG;
use FIG_Config;
use strict;
use File::Basename;
use Job48;
@ARGV == 1 or die "Usage: $0 job-dir\n";
my $jobdir = shift;
-d $jobdir or die "$0: job dir $jobdir does not exist\n";
my $genome = &FIG::file_head("$jobdir/GENOME_ID");
chomp $genome;
$genome =~ /^\d+\.\d+/ or die "$0: Cannnot find genome ID for jobdir $jobdir\n";
my $jobid = basename($jobdir);
my $job = new Job48($jobid);
my $meta_file = "$jobdir/meta.xml";
my $meta = new GenomeMeta($genome, $meta_file);
my $newD = "$jobdir/rp/$genome";
-d $newD or &fatal("genome directory $newD not found");
$meta->set_metadata("status.qc", "in_progress");
my $cmd = "$FIG_Config::bin/assess_gene_call_quality --meta=$meta_file $newD > $newD/quality.report 2>&1";
$meta->add_log_entry($0, $cmd);
my $rc = system($cmd);
$rc == 0 or &fatal("system $cmd failed with rc=$rc");
# Based on the results of the quality check, set up for user intervention.
my @corrections;
if ($meta->get_metadata('qc.RNA_overlaps') and
    $meta->get_metadata('qc.RNA_overlaps')->[1])
    push(@corrections, 'remove_rna_overlaps');
# remove_embedded_pegs
if ($meta->get_metadata('qc.Embedded') and
    $meta->get_metadata('qc.Embedded')->[1])
    push(@corrections, 'remove_embedded_pegs')
# If corrections are necessary, set up the status on the correction phase.
if (@corrections)
    # If we are automatically accepting corrections, set up for them to be executed.
    $meta->set_metadata("correction.possible", [@corrections]);
    my $automated_correction = $meta->get_metadata("correction.automatic");
    if ($automated_correction)
	$meta->set_metadata('correction.request', \@corrections);
	$meta->set_metadata('correction.acceptedby',
				 "automatic for " .$self->application->session->user->login);
	$meta->set_metadata('correction.timestamp', time());
	$meta->set_metadata("status.correction", 'not_started');
    else
	$meta->set_metadata("status.correction", 'requires_intervention');
	# Construct & send email.
	my $subject = "48-hour server job needs attention";
	my $gname = $job->genome_name;
	my $entry = $FIG_Config::fortyeight_home;
	$entry = "http://www.nmpdr.org/anno-server/" if $entry eq '';
	my $msg = <<END;
The annotation job that you submitted for $gname needs user input before it can proceed further.
You may query its status at $entry as job number $jobid
END
        $job->send_email_to_owner("qc.email_notification_sent", $subject, $msg);
else
    $meta->set_metadata("status.correction", "complete");
$meta->set_metadata("status.qc", "complete");
$meta->set_metadata("qc.running", "no");
sub fatal
    my($msg) = @_;
    $meta->add_log_entry($0, ['fatal error', $msg]);
    $meta->set_metadata("status.qc", "error");
    croak "$0: $msg";
