[Bio] / FortyEight / rp_quality_check.pl Repository:
View of /FortyEight/rp_quality_check.pl
Wed Nov 22 21:01:42 2006 UTC (13 years, 2 months ago) by olson
48hr mods
# -*- perl -*-
# Public License.
use strict;
use GenomeMeta;
use FIG;
use FIG_Config;
use strict;
use File::Basename;
@ARGV == 1 or die "Usage: $0 job-dir\n";
my $jobdir = shift;
-d $jobdir or die "$0: job dir $jobdir does not exist\n";
my $genome = &FIG::file_head("$jobdir/GENOME_ID");
chomp $genome;
$genome =~ /^\d+\.\d+/ or die "$0: Cannnot find genome ID for jobdir $jobdir\n";
my $meta_file = "$jobdir/meta.xml";
my $meta = new GenomeMeta($genome, $meta_file);
my $newD = "$jobdir/rp/$genome";
-d $newD or &fatal("genome directory $newD not found");
$meta->set_metadata("status.qc", "in_progress");
my $rc = system("$FIG_Config::bin/assess_gene_call_quality --meta=$meta_file $newD > $newD/quality.report 2>&1");
$meta->set_metadata("status.qc", "complete");
sub fatal
    my($msg) = @_;
    $meta->add_log_entry($0, ['fatal error', $msg]);
    $meta->set_metadata("status.auto_assign", "error");
    croak "$0: $msg";
