[Bio] / FortyEight / rp_make_CELLO_attributes.pl Repository:
Log of /FortyEight/rp_make_CELLO_attributes.pl
Wed Oct 17 15:32:29 2007 UTC (12 years, 5 months ago) by mkubal
writes/reads to /rp/genome
Thu Oct 11 20:16:20 2007 UTC (12 years, 5 months ago) by mkubal
Changes since 1.1: +6 -1 lines
writes to rp/genome/attributes dir
Thu Oct 11 17:03:49 2007 UTC (12 years, 6 months ago) by mkubal
v1
