[Bio] / FortyEight / rp_index_attributes.pl Repository:
Log of /FortyEight/rp_index_attributes.pl
Mon Oct 22 18:08:24 2007 UTC (12 years, 5 months ago) by olson
Changes since 1.3: +4 -1 lines
allow a second argument to be passed & ignored
Fri Oct 12 21:37:09 2007 UTC (12 years, 5 months ago) by olson
fix typo
Fri Oct 12 21:34:03 2007 UTC (12 years, 5 months ago) by olson
PUll attributes from teh attributes directory.
Thu Oct 11 18:32:16 2007 UTC (12 years, 5 months ago) by olson
attribute indexer
