[Bio] / FortyEight / rp_glimmer.pl Repository:
Log of /FortyEight/rp_glimmer.pl
Fri Oct 12 15:35:53 2007 UTC (12 years, 5 months ago) by olson
add the FIG bin and external bin dirs to the path so that run_glimmer2 can find stuff.
Wed Oct 10 20:50:55 2007 UTC (12 years, 5 months ago) by olson
Fri Oct 5 17:25:53 2007 UTC (12 years, 5 months ago) by olson
Updates to the Teach stuff. Small mod to build_nr to support condtional setting of sort buffer size.
Wed Oct 3 20:55:54 2007 UTC (12 years, 5 months ago) by olson
Pipeline scripts for computing critica and glimmer calls for the Teach project.
