[Bio] / FortyEight / rp_critica.pl Repository:
Log of /FortyEight/rp_critica.pl
Fri Oct 12 20:23:04 2007 UTC (12 years, 7 months ago) by olson
Changes since 1.3: +8 -0 lines
set up envirnment for critica perl
Wed Oct 10 20:50:55 2007 UTC (12 years, 7 months ago) by olson
Fri Oct 5 17:25:53 2007 UTC (12 years, 8 months ago) by olson
Changes since 1.1: +5 -4 lines
Updates to the Teach stuff. Small mod to build_nr to support condtional setting of sort buffer size.
Wed Oct 3 20:55:54 2007 UTC (12 years, 8 months ago) by olson
Pipeline scripts for computing critica and glimmer calls for the Teach project.
