[Bio] / FortyEight / rp_critica.pl Repository:
View of /FortyEight/rp_critica.pl
Revision 1.2 - (download) (as text) (annotate)
Fri Oct 5 17:25:53 2007 UTC (12 years, 7 months ago) by olson
Changes since 1.1: +5 -4 lines
Updates to the Teach stuff. Small mod to build_nr to support condtional setting of sort buffer size.
# Compute critica calls.
use Data::Dumper;
use Carp;
use strict;
use Job48;
use FIGV;
use FIG;
use FIG_Config;
use File::Basename;
use GenomeMeta;
use Sim;
@ARGV == 1 or die "Usage: $0 job-dir\n";
my $jobdir = shift;
-d $jobdir or die "$0: job dir $jobdir does not exist\n";
my $job = new Job48($jobdir);
$job or die "cannot create job for $jobdir";
my $hostname = `hostname`;
chomp $hostname;
my $genome = $job->genome_id();
my $meta = $job->meta();
$meta->add_log_entry($0, "start Critica processing on $hostname in $jobdir");
my $nt = "/vol/critica/seed-features.nt";
my $crit_bin = "/vol/critica/bin";
my $crit_scripts = "/vol/critica/scripts";
$ENV{CRITICA_BLASTN} = "$FIG_Config::ext_bin/blastall -p blastn";
$ENV{CRITICA_BLASTPARM} = "-gF -e1e-4";
$ENV{CRITICA_BLASTDB} = "-d $nt -i";
$ENV{PATH} = join(":", $ENV{PATH}, $crit_bin, $crit_scripts);
my $work = "$jobdir/critica_work";
my $orgdir = "$jobdir/rp/$genome";
my $contigs = "$orgdir/contigs";
&FIG::verify_dir($work);
chdir $work or &fatal("chdir $work failed: $!");
my $code = $meta->get_metadata("genome.genetic_code");
$code = 11 unless $code;
if (0 or (not -s "$work/orfs3.cds"))
    &run("$crit_scripts/blast-contigs $contigs > $work/contigs.blast");
    &run("$crit_scripts/make-blastpairs $work/contigs.blast > $work/contigs.blast.pairs");
    &run("$crit_bin/scanblastpairs $contigs $work/contigs.blast.pairs $work/contigs.triplets");
    &run("$crit_scripts/iterate-critica -genetic-code=$code $work/orfs $contigs $work/contigs.triplets");
# We should have our orfs finished in orfs3.cds now. Parse that and create
# critica features.
open(CRIT, "<$work/orfs3.cds") or &fatal("$work/orfs3.cds not readable: $!");
my $fdir = "$orgdir/Features/critica";
&FIG::verify_dir($fdir);
open(TBL, ">$fdir/tbl") or &fatal("Cannot open $fdir/tbl for writing: $!");
open(FA, ">$fdir/fasta") or &fatal("Cannot open $fdir/fasta for writing: $!");
my $id = 1;
my $figv = $job->get_figv();
my $code_table = &FIG::genetic_code($code);
while (<CRIT>)
    chomp;
    my($contig, $start, $stop, $pval, $mval, $comp, $dicod, $init_score,
       $init_seq, $sd1, $sd2, $sd3) = split(/\s+/);
    my $loc = join("_", $contig, $start, $stop);
    my $dna = $figv->dna_seq($genome, $loc);
    my $trans = &FIG::translate($dna, $code_table, 1);
    $trans =~ s/\*$//;
    my $cid = "fig|$genome.critica.$id";
    $id++;
    print TBL "$cid\t$loc\n";
    &FIG::display_id_and_seq($cid, \$trans, \*FA);
close(CRIT);
close(TBL);
close(FA);
$meta->add_log_entry($0, "finish critica computation on $jobdir");
$meta->set_metadata("status.critica", "complete");
exit(0);
sub run
    my(@cmd) = @_;
    print "Run @cmd\n";
    my $rc = system(@cmd);
    $rc == 0 or &fatal("Cmd failed with rc=$rc: @cmd");
sub fatal
    my($msg) = @_;
    if ($meta)
	$meta->add_log_entry($0, ['fatal error', $msg]);
	$meta->set_metadata("status.critica", "error");
    croak "$0: $msg";
