[Bio] / FortyEight / rp_chunk_sims.pl Repository:
Log of /FortyEight/rp_chunk_sims.pl
Wed Sep 5 20:59:03 2007 UTC (12 years, 4 months ago) by olson
Changes since 1.2: +18 -2 lines
Rollup of RAST->SEED import stuff.
Wed Nov 29 15:19:19 2006 UTC (13 years, 1 month ago) by olson
Rollup commit of 48hr changes.
Added add_virtual_genome to Subsystem.pm to support UnvSubsys doing
the right thing when handed a FIGV.
Added propagation of 48hr_job thru the various link generation scripts in order for protein.cgi/display_subsys.cgi
to properly show virtual genomes.
Wed Nov 22 21:01:42 2006 UTC (13 years, 2 months ago) by olson
48hr mods
