[Bio] / FortyEight / rp_chunk_sims.pl Repository:
Log of /FortyEight/rp_chunk_sims.pl
Wed Jul 8 20:18:46 2009 UTC (10 years, 4 months ago) by olson
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.4: +32 -13 lines
Add support for pulling sims from sims server and submitting only those that don't match to be computed.
Add use of $FIG_Config::rast_sims_data to point at the directory holding
nr & peg.synonyms; explicitly here for the purposes of more easily updating
to new sims databases.
Mon Mar 16 18:47:00 2009 UTC (10 years, 7 months ago) by olson
Changes since 1.3: +18 -1 lines
Add -include-self flag on rp_chunk_sims that cause the sims to the given fasta file to
be computed. Add that flag to the invocation in check_jobs.pl.
Wed Sep 5 20:59:03 2007 UTC (12 years, 2 months ago) by olson
Changes since 1.2: +18 -2 lines
Rollup of RAST->SEED import stuff.
Wed Nov 29 15:19:19 2006 UTC (12 years, 11 months ago) by olson
Rollup commit of 48hr changes.
Added add_virtual_genome to Subsystem.pm to support UnvSubsys doing
the right thing when handed a FIGV.
Added propagation of 48hr_job thru the various link generation scripts in order for protein.cgi/display_subsys.cgi
to properly show virtual genomes.
Wed Nov 22 21:01:42 2006 UTC (12 years, 11 months ago) by olson
48hr mods
