[Bio] / FortyEight / rp_auto_assign.pl Repository:
Log of /FortyEight/rp_auto_assign.pl
Wed Sep 5 21:43:18 2007 UTC (12 years, 3 months ago) by olson
fix compile errors
Fri Jun 8 19:20:20 2007 UTC (12 years, 6 months ago) by olson
add error reason to metadata
use expanded sims instead of unexpanded sims in autoassign
Wed Nov 29 15:19:19 2006 UTC (13 years ago) by olson
Changes since 1.2: +1 -22 lines
Rollup commit of 48hr changes.
Added add_virtual_genome to Subsystem.pm to support UnvSubsys doing
the right thing when handed a FIGV.
Added propagation of 48hr_job thru the various link generation scripts in order for protein.cgi/display_subsys.cgi
to properly show virtual genomes.
Fri Nov 24 20:44:08 2006 UTC (13 years ago) by olson
updates to 48 code
Wed Nov 22 21:01:42 2006 UTC (13 years ago) by olson
48hr mods
