[Bio] / FortyEight / rp_auto_assign.pl Repository:
Log of /FortyEight/rp_auto_assign.pl
Thu Jan 20 17:03:57 2011 UTC (8 years, 10 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.15: +6 -2 lines
Change default link to point to seed-viewer; add metadata for
dynamically pointing the link on future jobs.
Fri Dec 3 21:37:56 2010 UTC (9 years ago) by gdpusch
CVS Tags: rast_rel_2010_1206
Changes since 1.14: +56 -50 lines
Added metabolic reconstruction to this stage.
Tue Nov 23 20:12:16 2010 UTC (9 years ago) by gdpusch
Changes since 1.13: +20 -1 lines
Make sure that "Subsystems" and "Subsystems/bindings" are created (even if empty).
Fri Aug 27 22:00:16 2010 UTC (9 years, 3 months ago) by olson
CVS Tags: rast_rel_2010_0928
change model seed link
Thu Aug 19 15:51:08 2010 UTC (9 years, 3 months ago) by olson
CVS Tags: rast_rel_2010_0827
fix bad function call
Tue Aug 17 21:12:40 2010 UTC (9 years, 3 months ago) by olson
Changes since 1.10: +26 -3 lines
Fix creation of model links.
Thu Aug 5 18:09:11 2010 UTC (9 years, 4 months ago) by olson
fix model stuff
Wed Aug 4 15:03:40 2010 UTC (9 years, 4 months ago) by olson
Changes since 1.8: +16 -2 lines
add model creation
Wed Jul 28 21:14:20 2010 UTC (9 years, 4 months ago) by olson
Changes since 1.7: +11 -0 lines
Add stub for model-build invocation
Mon May 18 16:56:23 2009 UTC (10 years, 6 months ago) by olson
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526
Changes since 1.6: +1 -0 lines
set auto_assign.running to no when completed
Thu Jul 17 20:43:53 2008 UTC (11 years, 4 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_release_2008_09_29
Use -orgdir option to auto_assign in order to use indexed sims.
Wed Sep 5 21:43:18 2007 UTC (12 years, 3 months ago) by olson
fix compile errors
Fri Jun 8 19:20:20 2007 UTC (12 years, 6 months ago) by olson
add error reason to metadata
use expanded sims instead of unexpanded sims in autoassign
Wed Nov 29 15:19:19 2006 UTC (13 years ago) by olson
Changes since 1.2: +1 -22 lines
Rollup commit of 48hr changes.
Added add_virtual_genome to Subsystem.pm to support UnvSubsys doing
the right thing when handed a FIGV.
Added propagation of 48hr_job thru the various link generation scripts in order for protein.cgi/display_subsys.cgi
to properly show virtual genomes.
Fri Nov 24 20:44:08 2006 UTC (13 years ago) by olson
updates to 48 code
Wed Nov 22 21:01:42 2006 UTC (13 years ago) by olson
48hr mods
