[Bio] / FortyEight / rp_auto_assign.pl Repository:
Log of /FortyEight/rp_auto_assign.pl
Thu Jul 17 20:43:53 2008 UTC (11 years, 8 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_release_2008_09_29
Use -orgdir option to auto_assign in order to use indexed sims.
Wed Sep 5 21:43:18 2007 UTC (12 years, 6 months ago) by olson
fix compile errors
Fri Jun 8 19:20:20 2007 UTC (12 years, 9 months ago) by olson
add error reason to metadata
use expanded sims instead of unexpanded sims in autoassign
Wed Nov 29 15:19:19 2006 UTC (13 years, 4 months ago) by olson
Changes since 1.2: +1 -22 lines
Rollup commit of 48hr changes.
Added add_virtual_genome to Subsystem.pm to support UnvSubsys doing
the right thing when handed a FIGV.
Added propagation of 48hr_job thru the various link generation scripts in order for protein.cgi/display_subsys.cgi
to properly show virtual genomes.
Fri Nov 24 20:44:08 2006 UTC (13 years, 4 months ago) by olson
updates to 48 code
Wed Nov 22 21:01:42 2006 UTC (13 years, 4 months ago) by olson
48hr mods
