[Bio] / FortyEight / reset-failed-rp.pl Repository:
Log of /FortyEight/reset-failed-rp.pl
Fri Jan 14 12:42:37 2011 UTC (9 years ago) by gdpusch
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, rast_rel_2011_0119, rast_rel_2011_0928
Reset RP, and also any subsequent stages.
Fri Jan 14 12:18:34 2011 UTC (9 years ago) by gdpusch
Changes since 1.4: +15 -8 lines
Fri Jan 14 05:08:46 2011 UTC (9 years ago) by gdpusch
Changes since 1.3: +7 -7 lines
Reset whole job, not just RP.
Sat Jun 26 18:57:11 2010 UTC (9 years, 7 months ago) by gdpusch
CVS Tags: myrast_33, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.2: +28 -31 lines
Added automated removal of "CANCEL" file
Wed Mar 25 21:49:03 2009 UTC (10 years, 10 months ago) by olson
CVS Tags: rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526
Changes since 1.1: +17 -1 lines
Rollup of some bob-rast changes.
Mon Apr 7 20:07:27 2008 UTC (11 years, 9 months ago) by olson
Add reset-failed-rp which will fix a job which RP broke for.
