[Bio] / FortyEight / migrate_job.pl Repository:
Log of /FortyEight/migrate_job.pl
Links to mgrast_rel_2008_0923: (view) (download) (as text) (annotate)
Wed Jun 6 17:53:22 2007 UTC (13 years, 1 month ago) by olson
Changes since 1.1: +41 -3 lines
add -new option that assigns a new job number to the migrated job.
Thu May 31 17:05:46 2007 UTC (13 years, 1 month ago) by olson
Diff to selected 1.2
new script
