[Bio] / FortyEight / imp_check_tl_sim_status.pl Repository:
Log of /FortyEight/imp_check_tl_sim_status.pl
Links to mgrast_dev_02212011: (view) (download) (as text) (annotate)
Wed Sep 26 00:39:03 2007 UTC (12 years, 5 months ago) by olson
Changes since 1.1: +8 -0 lines
Import changes.
Wed Sep 5 20:59:03 2007 UTC (12 years, 5 months ago) by olson
Rollup of RAST->SEED import stuff.
