[Bio] / FortyEight / get_nmpdr_group.pl Repository:
Log of /FortyEight/get_nmpdr_group.pl
Wed Oct 31 23:20:32 2007 UTC (12 years, 5 months ago) by olson
Determine NMPDR group name for given genome name.
