[Bio] / FortyEight / find-genomes-not-in-seed.pl Repository:
Log of /FortyEight/find-genomes-not-in-seed.pl
Tue Feb 27 21:00:27 2007 UTC (12 years, 9 months ago) by olson
Changes since 1.2: +14 -0 lines
move email support to Job48
remove stopligth status
make quality_check set up correction.status and correction.request if corrections needed
Thu Feb 15 17:29:30 2007 UTC (12 years, 9 months ago) by olson
Changes since 1.1: +45 -3 lines
check_jobs.pl
Tue Jan 16 21:37:23 2007 UTC (12 years, 10 months ago) by olson
Add module to wrap up 48hr job lookups
Add script to find genomes in 48hr that aren't in seed.
Make BBHs colored purple on cluster cartoon
