[Bio] / FortyEight / find-genomes-not-in-seed.pl Repository:
Log of /FortyEight/find-genomes-not-in-seed.pl
Tue Feb 27 21:00:27 2007 UTC (13 years, 1 month ago) by olson
Changes since 1.2: +14 -0 lines
move email support to Job48
remove stopligth status
make quality_check set up correction.status and correction.request if corrections needed
Thu Feb 15 17:29:30 2007 UTC (13 years, 1 month ago) by olson
Changes since 1.1: +45 -3 lines
check_jobs.pl
Tue Jan 16 21:37:23 2007 UTC (13 years, 2 months ago) by olson
Add module to wrap up 48hr job lookups
Add script to find genomes in 48hr that aren't in seed.
Make BBHs colored purple on cluster cartoon
