[Bio] / FortyEight / create_import_job.pl Repository:
View of /FortyEight/create_import_job.pl
Wed Sep 5 21:41:46 2007 UTC (12 years, 4 months ago) by olson
new file
# Create a SEED-import job.
# The job initially has a listing of SEED fasta sources, NR fasta sources, and
# RAST fasta sources. The new NR will not have been built - it will be the first stage
# in the pipeline.
# For now we need to pass in the path to the NR and peg.synonyms files we are building from.
# We create the following files:
#    nr.dirs
#	Tab-delimited data of db-name, source path, size of fasta file
#    nr.sources
#	Listing of all fasta source files from which the nr is to be built
# We hardcode in the script, for now, the source locations of things. This is an ANL internal
# application at this point.
use strict;
use Data::Dumper;
use DirHandle;
use ImportJob;
use Job48;
use NRTools;
my $usage = "create_import_job prev-nr prev-syn prev-sims";
# Incoming NR data.
my $dir_biodb = "/vol/biodb";
#my $dir_biodb_nr_input = "$dir_biodb/processed_data/for_build_nr";
my $dir_biodb_nr_input = "/local/FIGdisk/FIG/Data/NR";
# Existing SEED data
#my $dir_reference_seed_data = "/vol/seed-data-anno-mirror/Data.Jan3";
my $dir_reference_seed_data = "/local/FIGdisk/FIG/Data";
# RAST server from which to pull genomes to import.
my $dir_rast_jobs = "/vol/48-hour/Jobs.prod.2007-0601";
# Startup.
@ARGV == 3 or die $usage;
my $prev_nr_src = shift;
my $prev_syn_src = shift;
my $prev_sim_dir = shift;
# Validate
if (open(F, "<$prev_nr_src"))
    $_ = <F>;
    if (! /^>/)
	die "$prev_nr_src does not look like a fasta file\n";
    close(F);
else
    die "Cannot open previous NR file $prev_nr_src: $!\n";
if (open(F, "<$prev_syn_src"))
    $_ = <F>;
    if (!/^xxx\d+,\d+\t/)
	die "$prev_syn_src does not look like a peg.synonyms file\n";
    close(F);
else
    die "Cannot open previous synonyms file $prev_syn_src: $!\n";
if (not(-d $prev_sim_dir and <$prev_sim_dir/sims*> > 0))
    die "previous sim dir $prev_sim_dir does not appear to contain sims\n";
# Initial validation.
&validate_dirs($dir_biodb_nr_input, $dir_reference_seed_data, $dir_rast_jobs);
# Create our jobdir.
my ($jobnum, $err) = ImportJob->create_new_job();
#my ($jobnum, $err) = ('002', undef);
if (!$jobnum)
    die "Create failed with error: $err\n";
my $job = ImportJob->new($jobnum);
my $jobdir = $job->dir;
$job->meta->add_log_entry($0, "creating new job");
# Symlink to prev_nr and prev_syn in the job directory.
my $prev_nr = "$jobdir/prev_nr";
my $prev_syn = "$jobdir/prev_syn";
my $prev_sims = "$jobdir/prev_sims";
unlink($prev_nr, $prev_syn, $prev_sims);
symlink($prev_nr_src, $prev_nr) or die "symlimk $prev_nr_src $prev_nr failed: $!";
symlink($prev_syn_src, $prev_syn) or die "symlimk $prev_syn_src $prev_syn failed: $!";
symlink($prev_sim_dir, $prev_sims) or die "symlimk $prev_sim_dir $prev_sims failed: $!";
# Build list of NR sources. We start with the directories in the reference
# SEED's NR dir, and override with anything in the biodb NR dir.
my %NR_dirs;
scan_NR_dir(\%NR_dirs, "$dir_reference_seed_data/NR");
scan_NR_dir(\%NR_dirs, "$dir_biodb_nr_input");
#scan_NR_dir(\%NR_dirs, "$dir_biodb_nr_input", { skip => qr(^(SwissProt|.*\.bak)) });
# And write to job dir.
open(F, ">$jobdir/nr.dirs");
for my $d (keys %NR_dirs)
    print F join("\t", $d, @{$NR_dirs{$d}}{'path', 'size'}), "\n";
close(F);
# Scan for SEED organisms.
scan_seed_dir(\%NR_dirs, "$dir_reference_seed_data/Organisms");
# Scan for RAST jobs to import.
my @rast_jobs;
scan_rast_jobs(\@rast_jobs, $dir_rast_jobs);
for my $job (@rast_jobs)
    my $gid = $job->genome_id;
    my $gname = $job->genome_name;
    my $j = $job->id;
    print "RAST job #$j: $gid $gname\n";
    if (exists($NR_dirs{$gid}))
	die "Rast job $j already exists in SEED server\n";
    my $fasta = $job->orgdir() . "/Features/peg/fasta";
    -f $fasta or die "Job $j has no fasta file in $fasta\n";
    $NR_dirs{$gid} = {type => "rast_job", name => $gname, path => $job->orgdir,
			    fasta_path => $fasta, size => -s _ };
open(F, ">$jobdir/all.nr.dirs");
open(F2, ">$jobdir/nr.sources");
for my $d (sort bydb keys %NR_dirs)
    print F2 $NR_dirs{$d}->{fasta_path} . "\n";
close(F);
close(F2);
sub bydb
    if ($a =~ /^(\d+)\.(\d+)$/)
	my($ga, $ia) = ($1, $2);
	if ($b =~ /^(\d+)\.(\d+)$/)
	    my($gb, $ib) = ($1, $2);
	    return $ga <=> $gb or $ia <=> $ib;
	else
	    return 1;
    elsif ($b =~ /^\d+\.\d+$/)
	return -1;
    else
	return $a cmp $b;
sub validate_dirs
    my(@dirs) = @_;
    my $err;
    for my $dir (@dirs)
	if (! -d $dir)
	    warn "Required directory $dir is not present\n";
	    $err++;
    exit(1) if $err;
