[Bio] / FortyEight / crc64.py Repository:
View of /FortyEight/crc64.py
Wed Feb 27 23:27:35 2008 UTC (11 years, 10 months ago) by mkubal
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
new
import sys
# Initialisation
# 32 first bits of generator polynomial for CRC64
# the 32 lower bits are assumed to be zero
POLY64REVh = 0xd8000000L
CRCTableh = [0] * 256
CRCTablel = [0] * 256
isInitialized = False
def CRC64(aString):
    global isInitialized
    crcl = 0
    crch = 0
    if (isInitialized is not True):
        isInitialized = True
        for i in xrange(256):
            partl = i
            parth = 0L
            for j in xrange(8):
                rflag = partl & 1L
                partl >>= 1L
                if (parth & 1):
                    partl |= (1L << 31L)
                parth >>= 1L
                if rflag:
	                parth ^= POLY64REVh
            CRCTableh[i] = parth;
            CRCTablel[i] = partl;
    for item in aString:
        shr = 0L
        shr = (crch & 0xFF) << 24
        temp1h = crch >> 8L
        temp1l = (crcl >> 8L) | shr
        tableindex = (crcl ^ ord(item)) & 0xFF
        crch = temp1h ^ CRCTableh[tableindex]
        crcl = temp1l ^ CRCTablel[tableindex]
    return (crch, crcl)
def CRC64digest(aString):
    return "%08X%08X" % (CRC64(aString))
if __name__ == '__main__':
    id = sys.argv[1]
    seq = sys.argv[2];
    crc = CRC64digest(seq)
    print id + "\t" + crc
