[Bio] / FortyEight / copy-raw-genome.pl Repository:
Log of /FortyEight/copy-raw-genome.pl
Fri Feb 2 16:42:52 2007 UTC (12 years, 9 months ago) by olson
use FIG_Config for jobs direcotry(backend)
Tue Nov 14 17:26:14 2006 UTC (13 years ago) by olson
Adding some utility stuff and the start of the master-check script.
