[Bio] / FortyEight / compute_job_signature.pl Repository:
Log of /FortyEight/compute_job_signature.pl
Wed Sep 28 21:37:41 2011 UTC (8 years, 4 months ago) by olson
CVS Tags: mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928
Add an explicit 'corrections.disabled' key for those cases where we
don't want any fixups to be computed. This is set for virus and keep-genecalls
runs; in these cases we want the check_jobs pre_pipeline logic to allow the
jobs to be executed as entirely batch-oriented runs. This will speed
the phage runs up a LOT.
Wed Sep 28 20:45:32 2011 UTC (8 years, 4 months ago) by olson
Add kmerDataset selection support.
Fri Jan 15 16:15:41 2010 UTC (10 years ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Add job caching support.
