[Bio] / FortyEight / compute_job_signature.pl Repository:
View of /FortyEight/compute_job_signature.pl
Revision 1.3 - (download) (as text) (annotate)
Wed Sep 28 21:37:41 2011 UTC (8 years, 4 months ago) by olson
CVS Tags: mgrast_version_3_2, mgrast_dev_12152011, mgrast_release_3_1_2, rast_rel_2011_0928, mgrast_dev_10262011
Add an explicit 'corrections.disabled' key for those cases where we
don't want any fixups to be computed. This is set for virus and keep-genecalls
runs; in these cases we want the check_jobs pre_pipeline logic to allow the
jobs to be executed as entirely batch-oriented runs. This will speed
the phage runs up a LOT.
use strict;
use Job48;
use Digest;
my $alg = 'SHA-256';
@ARGV == 1 or @ARGV == 2 or die "Usage: $0 job-dir [outfile]\n";
my $dir = shift;
my $out_fh;
if (@ARGV)
    my $outfile = shift;
    $out_fh = new FileHandle($outfile, "w");
    $out_fh or die "Cannot open output file $outfile: $!";
else
    $out_fh = \*STDOUT;
my $job = new Job48($dir);
my $meta = $job->meta;
# A signature is based on the metadata keys listed in
# @signature_keys below.
# It also includes a checksum of the original input file.
# This is found in the raw/<genome-id>/ directory.
# If it was a genbank job, file genbank_file has the original input.
# For either genbank or fasta files we include the checksum
# of the unformatted_contigs file.
# The genbank signature is not a simple signature; rather it
# is a set of the signatures of the individual genbank files
# that were concatenated to form the full file. They are sorted
# on locus id.
my @signature_keys = qw(use_glimmer
			correction.disabled
			correction.automatic
			correction.backfill_gaps
			correction.frameshifts
			genome.genetic_code
			keep_genecalls
			genome.contig_count
			genome.bp_count
			genome.ambig_count
			options.figfam_version
my @sig_data;
for my $key (@signature_keys)
    my $val = $meta->get_metadata($key);
    push(@sig_data, [$key, $val]);
my $raw_dir = $job->dir . "/raw/" . $job->genome_id;
my $md5 = '';
if (open(F, "<", "$raw_dir/unformatted_contigs"))
    my $d = Digest->new($alg);
    $d->addfile(\*F);
    $md5 = $d->hexdigest();
    close(F);
push(@sig_data, ['unformatted_contigs', $md5]);
if (open(F, "<", "$raw_dir/genbank_file"))
    my @segs;
    my $digest = Digest->new($alg);
    my $cur;
    my $l = <F>;
    while (defined($l))
	if ($l =~ /^LOCUS\s+(\S+)/)
	    $cur = $1;
	    $digest->add($l);
	    $l = <F>;
	elsif ($l =~ m,^//$,)
	    $digest->add($l);
	    my $md5 = $digest->hexdigest();
	    push(@segs, [$cur, $md5]);
	    # Spin until we hit the next start, in case there
	    # was text between the files. (If anything but blank lines,
	    # mark it with extra crud in the @segs list).
	    $l = <F>;
	    while (defined($l) && $l !~ /^LOCUS/)
		if ($l !~ /^\s*$/)
		    $digest->add($l);
		$l = <F>;
	    push(@segs, ["gap_$cur", $digest->hexdigest()])
	else
	    $digest->add($l);
	    $l = <F>;
    close(F);
    push(@sig_data, sort { $a->[0] cmp $b->[0] } @segs);
my $sig_txt = join("\n", map { join("\t", @$_) } @sig_data) . "\n";
$digest->add($sig_txt);
my $sig_md5 = $digest->hexdigest;
print $out_fh "$sig_md5\n$sig_txt";
close($out_fh);
