[Bio] / FortyEight / check_jobs_plasmid.pl Repository:
Log of /FortyEight/check_jobs_plasmid.pl
Wed Sep 2 17:05:36 2009 UTC (10 years, 2 months ago) by gdpusch
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.6: +5 -4 lines
Fixed call of wrong script instead of `rp_subsystem_coverage_plasmid`
Thu Aug 20 15:51:46 2009 UTC (10 years, 2 months ago) by arodri7
Changes since 1.5: +56 -0 lines
added subsystem coverage after auto assign
Mon Mar 16 19:48:43 2009 UTC (10 years, 8 months ago) by arodri7
CVS Tags: rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09
added chunk_sims flag
Sat Mar 14 15:17:59 2009 UTC (10 years, 8 months ago) by arodri7
Changes since 1.3: +133 -0 lines
revised errors
Thu Mar 12 21:13:03 2009 UTC (10 years, 8 months ago) by olson
fix $job
Thu Mar 12 03:04:17 2009 UTC (10 years, 8 months ago) by arodri7
Changes since 1.1: +10 -9 lines
changed ImportJobs to use Job package
Tue Mar 10 18:37:34 2009 UTC (10 years, 8 months ago) by arodri7
plasmid rast pipeline first version
