[Bio] / FortyEight / batch_rast.pl Repository:
Log of /FortyEight/batch_rast.pl
Wed Jan 27 17:35:29 2010 UTC (10 years ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.10: +36 -0 lines
more changes
Wed Jan 27 17:25:32 2010 UTC (10 years ago) by olson
More tweaks.
Tue Jan 19 19:26:51 2010 UTC (10 years, 1 month ago) by olson
Changes since 1.8: +7 -3 lines
Factor some of the pipeline code out into PipelineUtils.pm, more preening on check_jobs and batch_rast.
Tue Jan 19 17:16:32 2010 UTC (10 years, 1 month ago) by olson
Changes since 1.7: +77 -0 lines
add job completion code
Tue Jan 19 17:05:06 2010 UTC (10 years, 1 month ago) by olson
Add some logging.
Tue Jan 12 20:29:47 2010 UTC (10 years, 1 month ago) by olson
Changes since 1.5: +13 -6 lines
bugfix
Tue Jan 12 20:25:59 2010 UTC (10 years, 1 month ago) by olson
Changes since 1.4: +4 -4 lines
fix phases
Tue Jan 12 20:23:30 2010 UTC (10 years, 1 month ago) by olson
Changes since 1.3: +23 -5 lines
fixes for running under SGE
Mon Jan 4 20:30:23 2010 UTC (10 years, 1 month ago) by olson
Changes since 1.2: +50 -16 lines
mods from batch rasting
Thu Oct 29 21:21:37 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.1: +62 -0 lines
batch rast support
Mon Oct 26 21:23:37 2009 UTC (10 years, 3 months ago) by olson
New batch script
