[Bio] / FortyEight / batch_rast.pl Repository:
View of /FortyEight/batch_rast.pl
Revision 1.12 - (download) (as text) (annotate)
Wed Jun 8 21:00:28 2011 UTC (8 years, 7 months ago) by olson
CVS Tags: mgrast_dev_08112011, mgrast_dev_08022011, mgrast_version_3_2, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_release_3_1_1, rast_rel_2011_0928, mgrast_dev_10262011
Changes since 1.11: +37 -20 lines
Safety mods.
use strict;
use Carp;
use Job48;
use FIG_Config;
use FIG;
use Getopt::Long;
# Run a jobdirectory in one shot. For batch offload to a remote cluster that
# doesn't have our scheduler, etc available.
# Stages are as follows; for now this is a copy and paste exercise from
# FortyEight/check_jobs.pl. Use caution, don't run with scissors.
# upload
# rp
# Check status of keep_genecalls, then qc
# Check status of correction, then correction
# preprocess_sims
# sims
# bbhs
# auto_assign
# glue_contigs
# pchs
# scenario
# export
my $parallel = 1;
my @phase;
my $usage = "Usage: $0 [--parallel N] -phase N [--phase N ..] jobdir\n";
if (!GetOptions("parallel=i" => \$parallel,
		"phase=i" => \@phase))
    die $usage;
@ARGV == 1 or die $usage;
@phase > 0 or die $usage;
my %phase = map { $_ => 1 } @phase;
my $job_dir = shift;
# Only write process startup log if we're not doing sims
# or we're not in the SGE context. Otherwise we are
# flaying the NFS locking system badly.
my $log_subprocesses;
if (!$phase{3} || ($ENV{SGE_TASK_ID} eq '' || $ENV{SGE_TASK_ID} < 2))
    $log_subprocesses++;
if (-f "$job_dir/CANCEL")
    die "Job exiting due to earlier CANCEL\n";
my $job = new Job48($job_dir);
my $sims_data_dir = $FIG_Config::rast_sims_data;
if (!defined($sims_data_dir))
    $sims_data_dir = $FIG_Config::fortyeight_data;
my $sims_nr = "$sims_data_dir/nr";
my $sims_peg_synonyms = "$sims_data_dir/peg.synonyms";
my $sims_keep_count = 300;
my $job48 = new Job48($job_dir);
my $meta = $job48->meta;
my $host = `hostname`;
chomp $host;
$meta->add_log_entry($0, "Running phases @phase on $host") if $log_subprocesses;
# Emulate execution of SGE parallel environment via the
# --parallel N argument.
if ($parallel > 1)
    $ENV{PE} = 'cluster';
    $ENV{NSLOTS} = $parallel;
if ($phase{1})
    &do_upload($job);
    &do_rp($job);
if ($phase{2})
    &do_qc($job);
    &do_correction($job);
    &do_sims_preprocess($job);
if ($phase{3})
    # If running inside a SGE task array job, execute
    # our task. Otherwise run all of them.
    if ($ENV{SGE_TASK_ID})
	&run("$FIG_Config::bin/rp_compute_sims", $job->dir);
    else
	&do_sims($job);
if ($phase{4})
    &do_sims_postprocess($job);
    &do_bbhs($job);
    &do_auto_assign($job);
    &do_glue_contigs($job);
    &do_pchs($job);
    &do_scenario($job);
    &do_export($job);
    &mark_job_user_complete($job);
sub do_upload
    my($job) = @_;
    return;
sub do_rp
    my($job) = @_;
    &run("$FIG_Config::bin/rp_rapid_propagation", $job->dir);
sub do_qc
    my($job) = @_;
    if ($job->meta->get_metadata("keep_genecalls"))
	$job->meta->add_log_entry($0, "keep_genecalls is enabled: marking qc as complete");
	$job->meta->set_metadata("status.qc", "complete");
	return;
    &run("$FIG_Config::bin/rp_quality_check", $job->dir);
sub do_correction
    my($job) = @_;
	$job->meta->add_log_entry($0, "keep_genecalls is enabled: marking correction as complete");
	$job->meta->set_metadata("status.correction", "complete");
	return;
    my $correction_list = $job->meta->get_metadata("correction.request");
    if (ref($correction_list))
	my $correction_str = join(",", @$correction_list);
	&run("$FIG_Config::bin/rp_correction", $job->dir, $correction_str);
sub do_sims_preprocess
    my($job) = @_;
    &run("$FIG_Config::bin/rp_preprocess_sims", $job->dir, $sims_nr, $sims_peg_synonyms);
sub do_sims
    my($job) = @_;
    if (!open(CHUNK, "<", $job->dir.  "/sims.job/chunk.out"))
	die "Error opening $job_dir/sims.job/chunk.out: $!";
    # Extract created task ids
    my($task_start, $task_end);
    while (<CHUNK>)
	print;
	chomp;
	if (/^tasks\s+(\d+)\s+(\d+)/)
	    $task_start = $1;
	    $task_end = $2;
    close(CHUNK);
    if (!defined($task_start))
	die "Tasks not found";
    for my $task ($task_start .. $task_end)
	$ENV{SGE_TASK_ID} = $task;
sub do_sims_postprocess
    my($job) = @_;
    my $sims_nr_len = $sims_nr;
    if (-f "$sims_nr-len.btree")
	$sims_nr_len = "$sims_nr-len.btree";
    &run("$FIG_Config::bin/rp_postproc_sims", $job->dir, $sims_nr_len, $sims_peg_synonyms, $sims_keep_count);
sub do_bbhs
    my($job) = @_;
    &run("$FIG_Config::bin/rp_compute_bbhs", $job->dir);
sub do_auto_assign
    my($job) = @_;
    &run("$FIG_Config::bin/rp_auto_assign", $job->dir);
sub do_glue_contigs
    my($job) = @_;
    &run("$FIG_Config::bin/rp_glue_contigs", $job->dir);
sub do_pchs
    my($job) = @_;
    &run("$FIG_Config::bin/rp_compute_pchs", $job->dir);
sub do_scenario
    my($job) = @_;
    &run("$FIG_Config::bin/rp_scenarios", $job->dir);
sub do_export
    my($job) = @_;
    &run("$FIG_Config::bin/rp_write_exports", $job->dir);
sub mark_job_user_complete
    my($job) = @_;
    my $job_dir = $job->dir;
    my $meta = $job->meta;
    my $job_id = $job->id;
    system("$FIG_Config::bin/send_job_completion_email", $job_dir);
    $meta->set_metadata("status.final", "complete");
    # If the job is a SEED candidate, send VV email.
    if ($meta->get_metadata("import.suggested") or
	$meta->get_metadata("import.candidate"))
	my $gname = $job->genome_name;
	my $mail = Mail::Mailer->new();
	$mail->open({
	    To => 'Veronika Vonstein <veronika@thefig.info>, Robert Olson<olson@mcs.anl.gov>, Andreas Wilke<wilke@mcs.anl.gov>',
	    From => 'Annotation Server <rast@mcs.anl.gov>',
	    Subject => "RAST job $job_id marked for SEED inclusion",
	print $mail <<END;
RAST job #$job_id ($gname) was submitted for inclusion into the SEED, and has finished its processing.
END
    	$mail->close();
	# We also mark the job as ACTIVE again so that the
	# normal post-seed-acceptance pipeline stages may execute.
	open(F, ">$job_dir/ACTIVE");
	close(F);
    else
	# Otherwise it is completely done.
	&mark_job_done($job);
sub mark_job_done
    my($job) = @_;
    # If we spooled the job out onto the lustre disk, we need to
    # spool it back.
    if ($meta->get_metadata("lustre_required"))
	&run("$FIG_Config::bin/rp_lustre_finish", $job_dir);
    if (open(D, ">$job_dir/DONE"))
	print D time . "\n";
	close(D);
    else
	warn "Error opening $job_dir/DONE: $!\n";
    unlink("$job_dir/ACTIVE");
sub run
    my(@cmd) = @_;
    my $cmd_str = join(" ", @cmd);
    print "Start: $cmd_str\n";
    $meta->add_log_entry($0, ['Start', $cmd_str]) if $log_subprocesses;
    my $rc = system(@cmd);
    if ($rc != 0)
	$meta->add_log_entry($0, ['Failed', $rc, $cmd_str]);
	print STDERR "Failed: $rc $cmd_str\n";
	if (open(FH, ">", "$job_dir/CANCEL"))
	    print FH "Cancel job due to error in $0 @cmd\n";
	    close(FH);
	# Attempt to qdel any other parts of this job that are queued or running.
	# Only if we are running in the SGE environment.
	if ($ENV{SGE_ARCH} ne '')
	    my @jobs;
	    for my $k ($meta->get_metadata_keys())
		if ($k  =~ /p_.*\.sge_job_id/)
		    my $job_id = $meta->get_metadata($k);
		    # Don't qdel this job.
		    if ($job_id =~ /^\d+$/ && $job_id != $ENV{JOB_ID})
			push(@jobs, $job_id);
	    if (@jobs)
		my $rc2 = system("qdel", @jobs);
		print "qdel @jobs returned $rc2\n";
		$meta->add_log_entry($0, "Qdel @jobs due to failure returned status $rc2") if $log_subprocesses;
	confess "Cmd failed with rc=$rc: $cmd_str\n";
    $meta->add_log_entry($0, ['Done', $cmd_str]) if $log_subprocesses;
    print "Done: $cmd_str\n";
